NappyD13's avatar
NappyD13
Follower
Dec 31, 2016
Default SSID Still Broadcasting from ORBI after Changing to New SSID During Setup
After setting up ORBI and changing the SSID, it is still broadcasting the default SSID in addition to the new one.  Is this normal?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello NappyD13
    It should change to just the new one I would make sure the guest network is disabled and you may want to restart the router.
    DarrenM
