Anonymous
Dec 05, 2017Defect: OrbiOS 2.1.1.12 Attached Devices Widget & Page
In 2.1.12, the Attached Devices widget on the intitial page and the actual Attached Devices page do not populate even though devices and satellites are connected. Factory reset was performed mult...
- AnonymousDec 08, 2017
OP here:
I purchased an Eero yesterday (3 unit 2nd gen and 1 beacon) and received it around 6 PM. It was set up and has now run 16 hours without a single disconnect among 62 continually connected devices, or disconnects from another 30 devices that connect periodically as measured by a Fingbox, not anecdotal observation.
Other than having to enter about 30 port forwarding rules via an app versus a web interface, the setup was brainless and provides great feedback on node placement signal strength!
My RBK50 system with a router and 2 sats is packed in its boxes and on Craigslist. So glad to finally have stable wifi thanks to Eero!!
tomsliwowski
Dec 05, 2017Apprentice
No issue here. Did an upgrade from 2.0.0.74 with no resets.
