Retired_Member
Dec 05, 2017Defect: OrbiOS 2.1.1.12 Attached Devices Widget & Page
In 2.1.12, the Attached Devices widget on the intitial page and the actual Attached Devices page do not populate even though devices and satellites are connected. Factory reset was performed mult...
- Retired_MemberDec 08, 2017
OP here:
I purchased an Eero yesterday (3 unit 2nd gen and 1 beacon) and received it around 6 PM. It was set up and has now run 16 hours without a single disconnect among 62 continually connected devices, or disconnects from another 30 devices that connect periodically as measured by a Fingbox, not anecdotal observation.
Other than having to enter about 30 port forwarding rules via an app versus a web interface, the setup was brainless and provides great feedback on node placement signal strength!
My RBK50 system with a router and 2 sats is packed in its boxes and on Craigslist. So glad to finally have stable wifi thanks to Eero!!
Retired_Member
Dec 05, 2017
TonyTiger wrote:Hello,
Strange because it works for me?
spinkick also reported it in the above mentioned thread.
Retired_Member
Dec 05, 2017mkenny28 also reported it on the thread mentioned above.
- AmitRDec 05, 2017NETGEAR Employee Retired
We'll look into it. Btw, do you see the same issue using the Orbi Mobile App?
Orbi Product Team
- aani75Dec 05, 2017Apprentice
Nop, Mobile app is fine to show # of satellites connected but Mobile app also unable to display connected device list.
I was able to see connected devices if I manually reboot each satellite and once satellites are resynced. However, if I again reboot only router, it again starts showing 0 connected devices both in app and web interface.
- Retired_MemberDec 05, 2017
AmitR wrote:We'll look into it. Btw, do you see the same issue using the Orbi Mobile App?
Orbi Product Team
Orbi Product Team,
Some where in the back of my mind I seem to remember the first boot on a firmware having Orbi do something with the Attached Devices that takes several hours, especially with a bunch of devices, discovery? My Orbi CPU is between 75% and 80% for the past 6+ hours since it booted up on the new firmware. Is that normal? (I have between 70-90 devices connected at any time). Thank you.
- DarrenMDec 05, 2017Sr. NETGEAR Moderator
Have you guys tried to clear your browser cache or use another web browser? or even use another device to access the attached devices page?
DarrenM
- mastervisa30Dec 07, 2017Luminary
Now i got my first problem,no devices being shown.
I Have tried unplugged the main router and satellites and plugged in the main waited a minute then plugged in the satellites.
No devices being shown on my Orbi Mobile App,also doesnt work on web browser
This has never happend before this new firmware realese(Firmware-Version-2-1-1-12)
