Retired_Member
Dec 05, 2017Defect: OrbiOS 2.1.1.12 Attached Devices Widget & Page
In 2.1.12, the Attached Devices widget on the intitial page and the actual Attached Devices page do not populate even though devices and satellites are connected. Factory reset was performed mult...
- Retired_MemberDec 08, 2017
OP here:
I purchased an Eero yesterday (3 unit 2nd gen and 1 beacon) and received it around 6 PM. It was set up and has now run 16 hours without a single disconnect among 62 continually connected devices, or disconnects from another 30 devices that connect periodically as measured by a Fingbox, not anecdotal observation.
Other than having to enter about 30 port forwarding rules via an app versus a web interface, the setup was brainless and provides great feedback on node placement signal strength!
My RBK50 system with a router and 2 sats is packed in its boxes and on Craigslist. So glad to finally have stable wifi thanks to Eero!!
aani75
Dec 05, 2017Apprentice
Nop, Mobile app is fine to show # of satellites connected but Mobile app also unable to display connected device list.
alixvincent
Dec 06, 2017Tutor
Having exact same issue as reported by aani75. Desktop shows no satellites and no attatched devices. Mobile app shows correct number of satellites but no attatched devices.
- alixvincentDec 06, 2017Tutor
Update to my previous post: Now on desktop widget i see all 3 satellites, reported as disconnected. some of my attached devices are showning up. See attatched pdf. What am i supposed to do with the backhaul status? Thanks.
- Rich4Dec 06, 2017Aspirant
This is getting silly Netgear. I have the same issue with the no reported devices and no connected satellite. I did a factory reset and reloaded configuration and until I rebooted again all my connected devices came back. Sadly they all disappeared again when I did a reboot to try and get my satellite to connect, it was showing as disconnected when my devices came back. Following the same process to get the connected devices back again has not worked again (tried twice). With 2 teenage kids I was hanging out for the new parental controls, which I missed when upgrading from my D7800. I'm even having issues with setting up circle on android seeing the app getting stuck due to the wait indication (circling arrow) not progressing. All very frustrating.
- Retired_MemberDec 06, 2017
My runtime today has decreased to less than 30 minutes before reboots according to the disconnects and the Uptime on the debut.htm screen.
