Retired_Member
Dec 05, 2017Defect: OrbiOS 2.1.1.12 Attached Devices Widget & Page
In 2.1.12, the Attached Devices widget on the intitial page and the actual Attached Devices page do not populate even though devices and satellites are connected. Factory reset was performed mult...
- Retired_MemberDec 08, 2017
OP here:
I purchased an Eero yesterday (3 unit 2nd gen and 1 beacon) and received it around 6 PM. It was set up and has now run 16 hours without a single disconnect among 62 continually connected devices, or disconnects from another 30 devices that connect periodically as measured by a Fingbox, not anecdotal observation.
Other than having to enter about 30 port forwarding rules via an app versus a web interface, the setup was brainless and provides great feedback on node placement signal strength!
My RBK50 system with a router and 2 sats is packed in its boxes and on Craigslist. So glad to finally have stable wifi thanks to Eero!!
DarrenM
Dec 06, 2017Sr. NETGEAR Moderator
We are looking into the attached devices showing as 0 and I will also pass along the issue of the High CPU usage.
DarrenM
alixvincent
Dec 06, 2017Tutor
I reverted back to v. 2.0.0.74 and now everything works again. All attached devices are showing up again.
My Set up is RBR50 as AP and 3 RBS50.
- Rich4Dec 07, 2017Aspirant
alixvincent wrote:I reverted back to v. 2.0.0.74 and now everything works again. All attached devices are showing up again.
Cheers, I'm about to do the same. I should have done that straight away when I saw the thread rapidly expand when people were discovering the same "new features", but I really wanted the new parental control so stuck with it.
- Retired_MemberDec 07, 2017
The sad thing is, based on the past few disasters of releases, they'll auto update them all to the high CPU utilization rebooting router every 25 minutes version for us anyway.
It will affect some and not others. Then when they fix it, it'll affect the ones that weren't affected by it this time.
- mastervisa30Dec 07, 2017Luminary
Now i got my first problem,no devices being shown.
I Have tried unplugged the main router and satellites and plugged in the main waited a minute then plugged in the satellites.
No devices being shown on my app,web browser.
This has never happend before this new firmware realese(Firmware-Version-2-1-1-12)
- aani75Dec 07, 2017Apprentice
Welcome to the defect club :-)
- DarrenMDec 07, 2017Sr. NETGEAR Moderator
If you are having issues with High CPU usage or Attached devices showing 0 send me a Pm with your name, email and phone number also the serial and mac numbers of your orbi units. and I will get you over to our support team to work on these issues with you.
Thanks
DarrenM
- mastervisa30Dec 08, 2017Luminary
I reverted back to v. 2.0.0.76 beta last night and now everything works again :)
Now i can se my devices again :)
I think there is a Big bug in the latest firmware?
- harshakavuriDec 08, 2017GuideAfter rolling back to 2.0 it was stable for a day or so now I am having restart problem again. It restated 2 times last night itself.
cpu utilization seems to be normal - Retired_MemberDec 08, 2017
OP here:
