Retired_Member
Dec 05, 2017Defect: OrbiOS 2.1.1.12 Attached Devices Widget & Page
In 2.1.12, the Attached Devices widget on the intitial page and the actual Attached Devices page do not populate even though devices and satellites are connected. Factory reset was performed mult...
- Retired_MemberDec 08, 2017
OP here:
I purchased an Eero yesterday (3 unit 2nd gen and 1 beacon) and received it around 6 PM. It was set up and has now run 16 hours without a single disconnect among 62 continually connected devices, or disconnects from another 30 devices that connect periodically as measured by a Fingbox, not anecdotal observation.
Other than having to enter about 30 port forwarding rules via an app versus a web interface, the setup was brainless and provides great feedback on node placement signal strength!
My RBK50 system with a router and 2 sats is packed in its boxes and on Craigslist. So glad to finally have stable wifi thanks to Eero!!
DarrenM
Dec 07, 2017Sr. NETGEAR Moderator
If you are having issues with High CPU usage or Attached devices showing 0 send me a Pm with your name, email and phone number also the serial and mac numbers of your orbi units. and I will get you over to our support team to work on these issues with you.
Thanks
DarrenM
mastervisa30
Dec 08, 2017Luminary
I reverted back to v. 2.0.0.76 beta last night and now everything works again :)
Now i can se my devices again :)
I think there is a Big bug in the latest firmware?
- harshakavuriDec 08, 2017GuideAfter rolling back to 2.0 it was stable for a day or so now I am having restart problem again. It restated 2 times last night itself.
cpu utilization seems to be normal - Retired_MemberDec 08, 2017
OP here:
