Retired_Member
Dec 05, 2017Defect: OrbiOS 2.1.1.12 Attached Devices Widget & Page
In 2.1.12, the Attached Devices widget on the intitial page and the actual Attached Devices page do not populate even though devices and satellites are connected. Factory reset was performed mult...
- Retired_MemberDec 08, 2017
OP here:
I purchased an Eero yesterday (3 unit 2nd gen and 1 beacon) and received it around 6 PM. It was set up and has now run 16 hours without a single disconnect among 62 continually connected devices, or disconnects from another 30 devices that connect periodically as measured by a Fingbox, not anecdotal observation.
Other than having to enter about 30 port forwarding rules via an app versus a web interface, the setup was brainless and provides great feedback on node placement signal strength!
My RBK50 system with a router and 2 sats is packed in its boxes and on Craigslist. So glad to finally have stable wifi thanks to Eero!!
spinkick
Dec 10, 2017Apprentice
I, too had tons of problems with this firmware. I dont understand why net gear can't make this hardware work after all of this time. I get the feeling they are relying on the chipset Manufacturers to make it right and all they do is build features around what they are given.
Anyway, I was only getting 40 mbps on my devices as well with this firmware. I have up and went back to the 2.0.76 firmware and it's been much more stable and getting full speed again.
Netgear, what is the problem?
JMU1998
Dec 10, 2017Luminary
Has anyone tried a nvram clear? Does a factory reset clear nvram as well?
- aazDec 12, 2017Virtuoso
I'm going to suggest what should be a silly thing, but it had an affect on my RBK50. Save the current config to a backup, and then restore it.
You may have to reset the whole thing after 15 minutes if the satellites don't reconnect, but after that both satellites connected and I now see all devices in the list and network is stable. (though the list is still wrong saying that all my devices are connected to the router instead of the satellites, and they need to fix this ASAP.)
This should not really be a possible fix for anything if everything worked perfectly, but there are obvious upgrade bugs in this firmware that are doing something funky, and a restore seems to change it enough to make it work.
- ratickleDec 20, 2017Apprentice
JMU1998 wrote:Has anyone tried a nvram clear? Does a factory reset clear nvram as well?
This is an important question. Can anyone out there answer it?
Do we have to use telnet to clear nvram?- aazDec 20, 2017Virtuoso
I don't know for sure, but someone mentioned that doing a reset does not clear nvram completely because they've seen some settings that carried over in the config after a reset. Only doing it through telnet does that apparently.
However, I've never found it necessary to do that, even after upgrading the very old 1.0 firmware when I first aquired the device from costco 3 months ago.
