CaraBethP
Jul 12, 2023Tutor
Desktop Computer and RBR-50
RBR50 plus satellite, Firmware version: V2.7.4.24, Windows 11, Summary of the problem: Every digital device in our house runs at awesome speed. My brand new Dell XPS 8950 desktop is connected wirele...
- Jul 12, 2023
I think I just fixed it.
Device Manager/Network Adapters/ right click the wireless adapter/ Properties/ Select Preferred Band/ on the right change it to 5g
I rebooted my computer and now it shows that it has connected to the 5g. And my speed is nearly 5 mbps!
I wish I had figured this out sooner!
Thanks for the help!
CrimpOn
Jul 12, 2023Guru - Experienced User
I'm pretty sure you have already "forgotten" the Orbi SSID (cardinal?).
Then, selected it from the list of available WiFi systems and connected again.
Correct?
On the WiFi adapter, can you look for something similar to this:
Here, my laptop is set to 802.11ax (even though my ancient Orbi RBR50 does not support ax. The laptop connects at 5G.
CrimpOn
sorry. our posts "crossed".
Glad you got it working!
