bent_wookie
May 01, 2018Star
Despite disabling autoupdate via telnet, infected by 2.1.4 and now I can't see my printer
After months of problems with my Orbi's dying randomly, the V2.1.3.4 "beta" seemed to mostly work. I then locked my router and satellites using the telnet procedure. Or so I thought.
An hour ag...
May 02, 2018Guru - Experienced User
Good Luck in your endeavours.
