bjornand1
Jun 17, 2020Aspirant
Despite trying all advice from various threads, my Orbi 50 system wifi speed is very low
Hi, I have been very pleased with my Orbi system for a long time, but recently I have discovered that my WiFi speed has dropped dramatically - even standing right next to the Orbi base station, the d...
Jun 18, 2020Guru - Experienced User
What are your wired speed results?
Press the back reset button for 15 seconds then release.
- bjornand1Jun 19, 2020Aspirant
Hi Furry, thanks for responding!
Let me first answer your questions:
What Firmware version is currently loaded? 2.5.1.16
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Zyxel P2812ac
What are your wired speed results? 500+ Mbps up and down
What is the distance between the router and satellite(s)? About 30 feet between the RBR and two of the RBSs, probably around 45 feet to the third RBSWhat channels are you using? 11 for 2.4 and 36 for 5 GHz
Any Wifi Neighbors near by? If so, how many? We live in a very rural area so I can only barely detect the neighbor's network
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Should I try them all at once or one at the time? I did something to these once earlier, but at some point my Home Connected washing machine would no longer be able to connect - any idea which, if any of these, causes that issue?
Has a factory reset and setup from scratch been performed since last FW update? No, would that involve a lot of effort? I mostly fear having my smart home devices getting into trouble, but I guess resetting and setting the same network name/password won't cause much trouble?
FURRYe38, one more thing, I have used Netspot and WiFi Explorer to analyse the network, and all seems fine, with low noise and good signal strengths. However, I notice that for the 5 GHz networks, the max rate is shown as 54 Mbps, as opposed to 400 for the 2.4 GHz ones. Is that normal?
- FURRYe38Jun 19, 2020Guru - Experienced User
You modem is a router and wifi built in. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYes, when doing a reset, one can use the same SSID name and PW.
Load WiFi Sweetspots on a mobile device to see the connection rate with a device connected to the RBR.
