bjornand1
Jun 17, 2020Aspirant
Despite trying all advice from various threads, my Orbi 50 system wifi speed is very low
Hi, I have been very pleased with my Orbi system for a long time, but recently I have discovered that my WiFi speed has dropped dramatically - even standing right next to the Orbi base station, the d...
Jun 18, 2020Guru - Experienced User
What are your wired speed results?
Press the back reset button for 15 seconds then release.
bjornand1
Jun 19, 2020Aspirant
FURRYe38, one more thing, I have used Netspot and WiFi Explorer to analyse the network, and all seems fine, with low noise and good signal strengths. However, I notice that for the 5 GHz networks, the max rate is shown as 54 Mbps, as opposed to 400 for the 2.4 GHz ones. Is that normal?
- FURRYe38Jun 19, 2020Guru - Experienced User
You modem is a router and wifi built in. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYes, when doing a reset, one can use the same SSID name and PW.
Load WiFi Sweetspots on a mobile device to see the connection rate with a device connected to the RBR.
- bjornand1Jun 19, 2020Aspirant
Thanks for following up!
The Zyxel router is in bridge mode, so that can not be the issue.
But you think a factory reset would help?
Yes, Reset. Besure to not enable Access controls, Armor, Circle or Traffic meter. Soon as the setup wizard is completed, run a wired speed test with a couple of different wired PCs using ooklas installable speed test app with the RBR. I would not connect everything else until testing is done. Turn off all wifi and wired devices accept for 1 or 2 wired PCs. You don't want any interferences during speed testing to be sure.
