bjornand1
Jun 17, 2020Aspirant
Despite trying all advice from various threads, my Orbi 50 system wifi speed is very low
Hi, I have been very pleased with my Orbi system for a long time, but recently I have discovered that my WiFi speed has dropped dramatically - even standing right next to the Orbi base station, the d...
bjornand1
Jun 19, 2020Aspirant
FURRYe38, one more thing, I have used Netspot and WiFi Explorer to analyse the network, and all seems fine, with low noise and good signal strengths. However, I notice that for the 5 GHz networks, the max rate is shown as 54 Mbps, as opposed to 400 for the 2.4 GHz ones. Is that normal?
Jun 19, 2020Guru - Experienced User
You modem is a router and wifi built in. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Yes, when doing a reset, one can use the same SSID name and PW.
Load WiFi Sweetspots on a mobile device to see the connection rate with a device connected to the RBR.
- bjornand1Jun 19, 2020Aspirant
Thanks for following up!
The Zyxel router is in bridge mode, so that can not be the issue.
But you think a factory reset would help?
- FURRYe38Jun 19, 2020Guru - Experienced User
Yes, Reset. Besure to not enable Access controls, Armor, Circle or Traffic meter. Soon as the setup wizard is completed, run a wired speed test with a couple of different wired PCs using ooklas installable speed test app with the RBR. I would not connect everything else until testing is done. Turn off all wifi and wired devices accept for 1 or 2 wired PCs. You don't want any interferences during speed testing to be sure.
- bjornand1Jul 09, 2020Aspirant
Hi, FURRYe38, with summer vacation going on, I have not had much time to look at this lately. I am also hesitant to reset the system, as I have so many smart home devices with reserved DHCP addresses, which I fear will create problems in a reset.
One additional question; I have the option to easily connect one of the satelites (which covers the most important area of the house) through ethernet (the other two satelites are out of reach for this). Is it possible to have such a mixed setiup, with one satelite over ethernet and the other two wirelessly, and can it alleviate my low speed problem?
