bramsche
Jan 13, 2018Follower
Detecting Ethernet Connections
Hello. So I have the RBR50 and the Sattelite and they work great. However, I noticed when I connect my iMac via Ethernet, it longer shows up under the Device list. Furthermore, when I go into t...
guzzijason
Jan 13, 2018Apprentice
There have been bugs with the recent version UI and the connected device list. If your iMac is working OK when directly connected, then I wouldn't worry about what the connected device list displays in the UI. Hopefully, the next software update fixes it.
