Onedark1
Sep 28, 2017Initiate
Determining 2.4 GHz or 5GHz on Orbi
Hello! I have read a few posts on the fourm, and wanted to know how do I determine if I am using the 2.4 or 5GHz channel? Thanks in advance!
- Sep 28, 2017
you can usually check on your client devices wireless adapters status as to what speed its connected at , the other way is to access the gui of the orbi router and look at the attached device list as its tells you both what band each device is connected to and what each is also connected to ( eg router or sat/s by mac address )
Betoxyz68
Sep 29, 2017Aspirant
Can Orbi be forced to transmit in 5GHz only? This is a deciding factor if I buy this system?
st_shaw
Sep 29, 2017Master
Betoxyz68 wrote:Can Orbi be forced to transmit in 5GHz only? This is a deciding factor if I buy this system?
No. The 2.4 GHz power can be lowered but not turned off. Why do you need a 5 GHz only system?
- Betoxyz68Sep 29, 2017Aspirant
Thank you for your quick response. I currently have 1 Netgear Nighthawk router in the middle of my 3,000 sq/ft single floor home with upto 1,000 Mbps internet speed. Wirelessly I get 322 down/158 up using 5 ghz and 63 down/13 up using 2.4 ghz while in the same room with the router on my iPhone 7. I’m struggling with my outdoor Nest cameras since they are the furthest from my router. Since I can currently choose between 2.5 and 5.0 ghz I found the 5 works the best. The extender that Cosme with my router does not help. I’m concerned that not having the ability to choose 5.0 ghz it will not solve my cameras issue.
- st_shawSep 29, 2017Master
Betoxyz68 wrote:Thank you for your quick response. I currently have 1 Netgear Nighthawk router in the middle of my 3,000 sq/ft single floor home with upto 1,000 Mbps internet speed. Wirelessly I get 322 down/158 up using 5 ghz and 63 down/13 up using 2.4 ghz while in the same room with the router on my iPhone 7. I’m struggling with my outdoor Nest cameras since they are the furthest from my router. Since I can currently choose between 2.5 and 5.0 ghz I found the 5 works the best. The extender that Cosme with my router does not help. I’m concerned that not having the ability to choose 5.0 ghz it will not solve my cameras issue.
The reason you want both 5 GHz and 2.4 GHz is because 2.4 penetrates walls much better and travels four to five times farther. If you operate with 5 GHz only, your far away cameras will likely perform poorly.
