mcdermottm
Apr 17, 2019Aspirant
Device connecting to furthest satellite
Hello. I have installed a wifi connected landscape lighting controller. I mounted the wifi antenna inside a storage room that is less than 10 feet from an Orbi satellite but has a standard wood frame...
Apr 17, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain. Save settings and reboot the router and satellite(s).
