mcdermottm
Apr 17, 2019Aspirant
Device connecting to furthest satellite
Hello. I have installed a wifi connected landscape lighting controller. I mounted the wifi antenna inside a storage room that is less than 10 feet from an Orbi satellite but has a standard wood frame...
mcdermottm
Thanks for the replies.
I havent delved too deeply into the Orbi itself, and not since I installed it in November, but I don’t remember seeing any of the advanced options like on the Nighthawk I tried. I’m guessing they’re in there somewhere?
I thought I fixed the issue with the lighting controller manufacturer but the problem still persists and I don’t know if it’s their problem or with Orbi. The controller is logged in to the network and it usually shows upon the Orbi devices list, although with a weaker signal than the few times it has connected to the closest satellite. The problem is it doesn’t show as on the “available” list with the manufacturer’s app.
Apr 17, 2019Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings
- mcdermottmApr 17, 2019Aspirant
Well, that seems like a logical place to find it. 😆 I’ll check it out. Thanks.
