finny23j
May 15, 2020Aspirant
Device having issues with Circle enabled
Hi all,
I have enabled Circle on my Orbi. I am running into a single specific issue with the Google Pixel 3.
It started holding on to the bedtime schedule. So I removed the device from circle. When we reconnect the device to the Orbi, it does not show up and also it does not get added back in to the Circle as a device.
Any one have a thoughts on this, or should I do a factory reset of the Circle settings on the Orbi to see if this resolves it?
Thanks in advance
Alas, my impression is that most of the people who participate in this community forum have not activated Circle. (I never have.)
You are more likely to get an informed response by posting in the Netgear forum specifically devoted to Circle:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
- finny23jAspirant
Thanks for the response. I will try in that forum area.
