dpdurst
Aug 16, 2020Luminary
Device list still messed up
So the device list is still messed up, it worked fine so it appears in 2.5.1.16 since I had all 27 devices showing up. Starting in the 2.5.1.32? release I think it was I no longer would see any non-D...
- Aug 24, 2020
Moved on to another router this issue is resolved. Love the Orbi but honestly lack of support is incredible, and constantly hearing to default is just lame!
Mstrbig
Aug 16, 2020Master
Maybe that's why Netgear has still NOT publically posted the new firmware.
My RBK53 system devices have not automatically updated, nor tell me I have new firmware waiting.
- dpdurstAug 16, 2020Luminary
Possibly, I saw this same behavior in the previous release they pulled but it didn't last long enough for me loaded on the Orbi to pin this down as to what might be causing it or making it stuck. If they know about it cool, if not there seems to be an issue and I have captured that now. I'm good on this release since I know all devices are working fine, we'll see what else pops up if it does..
- MstrbigAug 16, 2020MasterI was going to manual update, as I am big on running the latest firmware. But decided not to since my system is rock solid on .15. Add to that the track record Netgear has for releasing unstable firmware. I always run OpenWRT on netgear routers I install for that reason.
Funny I run OpenWRT on a few routers I use at work. I wasn't going to upgrade but was curious about the DHCP device display issue. So now I know but that so far seems to be the only thing I found not correct. You know, I thought the company I worked for was the only one that could mess up a software build, I guess there are other's out there as well. It seems Netgear however is a bit more constant on things working and then not working between builds. Just not getting it, well I do but don't.. lol
