dpdurst
Aug 16, 2020Luminary
Device list still messed up
So the device list is still messed up, it worked fine so it appears in 2.5.1.16 since I had all 27 devices showing up. Starting in the 2.5.1.32? release I think it was I no longer would see any non-D...
- Aug 24, 2020
Moved on to another router this issue is resolved. Love the Orbi but honestly lack of support is incredible, and constantly hearing to default is just lame!
dpdurst
Funny I run OpenWRT on a few routers I use at work. I wasn't going to upgrade but was curious about the DHCP device display issue. So now I know but that so far seems to be the only thing I found not correct. You know, I thought the company I worked for was the only one that could mess up a software build, I guess there are other's out there as well. It seems Netgear however is a bit more constant on things working and then not working between builds. Just not getting it, well I do but don't.. lol
dpdurst
Aug 24, 2020Luminary
