migsta
Sep 28, 2019Apprentice
Device List
Across ALL NETGEAR routers the device list is just in a complete MESS with respect to the GUI or iOS app. Any model, RAX120, RAX80, RBR50, etc. The device names and types either get reset or don’t tak...
Joonbug99
Dec 18, 2019Aspirant
I have an orbi RBK50. Up until the last update I had all of my devices named perfectly under the device list. After the last update the names all got reset to messy unidentifiable names. I renamed all of them (over 50) and closed the app. I went back in and nothing was saved. I can’t correct the names of my devices. This is terrible!!!!! PLEASE FIX THIS. PLEASE!!
tomschmidt
Dec 19, 2019Virtuoso
For your RBK50 (RBR50 and RBS50), upgrade your firmware to v2.5.1.8, as it corrects the device naming issue seen with the v2.5.0.x firmware. Login to your router, and check for new firmware (Click Advanced tab and navigate to Adminstration -> Firmware Update). If the v2.5.1.8 does not appear there, then you can download it manually from https://www.netgear.com/support/product/RBK50.aspx#download
- Joonbug99Dec 19, 2019AspirantThank you for you fast response. I am running v2.5.0.38. When I look for an update it says “no new firmware version available” I logged in via my phone and a laptop and got the same message.
- DexterJBDec 19, 2019NETGEAR Moderator
Hi Joonbug99, as advised by tomschmidt, you can manually update the firmware for your Orbi router. The link below may help out.
Dexter
- Joonbug99Dec 19, 2019AspirantYou are all awesome!!! Thanks for getting me this information. I found them and installed them. A bit cumbersome for pricey hardware but I love the orbi. Thanks again.
