JamesAmazing
Apr 06, 2020Star
Device Manager does not display all connected devices
Upgraded to 2.1.5.8 firmware today and I only have 5 devices shown as connected. WTH!?! I had almost 25 before and that means I can’t pause them. It was working great before and now I can’t shut off t...
- Apr 08, 2020I downgraded to the 2.3.5.30 firmware and everything is good! All devices are showing up and connected to satellites. Don’t upgrade if you have an RBR50 AX3000 system!
Apr 07, 2020Guru - Experienced User
Please try a factory reset and setup from scratch with the RBR and RBS.
Be sure you update the Orbi app as well if thats what you are using...
JamesAmazing wrote:
Upgraded to 2.1.5.8 firmware today and I only have 5 devices shown as connected. WTH!?! I had almost 25 before and that means I can’t pause them. It was working great before and now I can’t shut off the boys wifi
- JamesAmazingApr 07, 2020StarI’ll give it a go. I just rebooted. Now it only shows 3. 2 wired and 1 unknown.
Frustrating.
Thanks for the reply, I’ll let you know.- FURRYe38Apr 07, 2020Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).- JamesAmazingApr 07, 2020StarWow. This is wonky. So I reset everything and did a fresh setup. The app says all is connected but everything is connected either to Orbi Router or RbS50 1. Nothing is connected to Satellite 2. From the web interface it says Satellite 2 is not connected
