JamesAmazing
Apr 06, 2020Star
Device Manager does not display all connected devices
Upgraded to 2.1.5.8 firmware today and I only have 5 devices shown as connected. WTH!?! I had almost 25 before and that means I can’t pause them. It was working great before and now I can’t shut off t...
- Apr 08, 2020I downgraded to the 2.3.5.30 firmware and everything is good! All devices are showing up and connected to satellites. Don’t upgrade if you have an RBR50 AX3000 system!
ekhalil
Apr 06, 2020Master
Do you mean that few devices now have internet connection but are not shown in the Attached Devices?
Please try disabling Access Control under >> ADVANCED >> Security >> Access Control >> in the web GUI the click Apply.
See then if you’ll see all devices now. If you see all devices then you can start using the access control again.
JamesAmazing
Apr 07, 2020Star
Access Control is disabled. Almost all of the devices in my house are not showing up in the list. It seems everytime I reboot different devices show up. It is wonky. I had 24 connected before, now it only displays 7 : S
- FURRYe38Apr 07, 2020Guru - Experienced User
You might try this, power OFF all of your devices. Leaving one wired PC connected to the RBR. I would then setup a IP address reservation for the PC, save and apply. Then power on a device. Do the same thing. IP address reservation, save and apply. Try adding devices 1 at a time and set an IP address reservation.
Wondering if the IP address pool cache is getting hosed up thus the devices are not displaying correctly.
- ekhalilApr 07, 2020MasterAre you really sure the devices are attached to Orbi and not to another wifi? :)
Please check on the devices that the assigned IP addresses belong to the IP range of Orbi.- JamesAmazingApr 08, 2020StarI downgraded to the 2.3.5.30 firmware and everything is good! All devices are showing up and connected to satellites. Don’t upgrade if you have an RBR50 AX3000 system!
- FURRYe38Apr 08, 2020Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
- OrbiJesApr 10, 2020Aspirant
i am seeing the same behavior, probably since the 2.8.1.5 fw. IE not all devices are listed, they only shown as connected to RBR. Satellite shown as Disconnected in Web UI but app and otherwise devices have connectivities. It feels like FW bugs, hope the next update will bring fixes. I am also getting sporatic latencies between devices in addition of the issues mentioned in this thread, which brought me to this forum.
- JamesAmazingApr 10, 2020StarSave yourself the headache and downgrade the firmware.
