JamesAmazing
Apr 06, 2020Star
Device Manager does not display all connected devices
Upgraded to 2.1.5.8 firmware today and I only have 5 devices shown as connected. WTH!?! I had almost 25 before and that means I can’t pause them. It was working great before and now I can’t shut off t...
- Apr 08, 2020I downgraded to the 2.3.5.30 firmware and everything is good! All devices are showing up and connected to satellites. Don’t upgrade if you have an RBR50 AX3000 system!
JamesAmazing
Apr 07, 2020Star
Access Control is disabled. Almost all of the devices in my house are not showing up in the list. It seems everytime I reboot different devices show up. It is wonky. I had 24 connected before, now it only displays 7 : S
Apr 07, 2020Guru - Experienced User
You might try this, power OFF all of your devices. Leaving one wired PC connected to the RBR. I would then setup a IP address reservation for the PC, save and apply. Then power on a device. Do the same thing. IP address reservation, save and apply. Try adding devices 1 at a time and set an IP address reservation.
Wondering if the IP address pool cache is getting hosed up thus the devices are not displaying correctly.
