JamesAmazing
Apr 06, 2020Star
Device Manager does not display all connected devices
Upgraded to 2.1.5.8 firmware today and I only have 5 devices shown as connected. WTH!?! I had almost 25 before and that means I can’t pause them. It was working great before and now I can’t shut off t...
- Apr 08, 2020I downgraded to the 2.3.5.30 firmware and everything is good! All devices are showing up and connected to satellites. Don’t upgrade if you have an RBR50 AX3000 system!
OrbiJes
Apr 11, 2020Aspirant
So I see a banner now says it's solved, with a link to solution. I followed link that went to a follow up post, which has a link that says solution is in the original post, that link doesn't go anywhere. I went thru entire thread and found an external link to some custom fw but not finding info on how to downgrade nor where to get older fw. Search result weren't useful... Is this really solved? thanks.
SW_
Apr 11, 2020Prodigy
You can rollback to a previous version by re-installing your previous version over the current version. All supported RBK50 firmware versions can be downloaded from here.
To (re)install firmware, head over to ADVANCED Firmware Update page and select the Manual Update. Then upload the firmware version you want to install. Repeate the same steps for all the Satellites. To access the Satellite UI, points your browser at its IP address.
Good luck!
- OrbiJesApr 12, 2020Aspirant
found the place for older FW! it's a little text at the end of list of items! I am able to install the fw successfully and all devices and satelite status and number of little things are all back to normal. I'll have to do more test to see if high latency issue continues. Thanks!
