djhurlburt
Jan 27, 2020Apprentice
device not connecting to closest satellite
It looks like many have a similar problem. I have an RBR50 along with 2 satellites. My router is on my main floor with 1 satellite upstairs and 1 satellite in the basement. In my master bedroom, I...
tmwsiy99
Aug 15, 2020Tutor
I have the exact same problem. 40 devices in the house typically connecting to the closest unit and system is mostly fast. HOWEVER, there is an exception with one desktop computer that seems to prefer the satellite versus the main unit. The satellite is two floors away on the other side of the house. The main unit is 20 feet away. If I unplug the satellite, the computer will happily connect to main unit with speeds around 100Mbs. If I then replug the satellite, within an hour, the computer will connect to it and I will get 500Kbps at best. And THEN sometimes the connection drops altogether but will not then reconnect to the main. It is terribly frustrating.
Mstrbig
Aug 16, 2020Master
I have the same issue from time to time. I go to the device, forget the Wireless networks and re-connect. It always picks the strongest signal and stayus connected until the closest satellite goes offline for some reason.
