djhurlburt
Jan 27, 2020Apprentice
device not connecting to closest satellite
It looks like many have a similar problem. I have an RBR50 along with 2 satellites. My router is on my main floor with 1 satellite upstairs and 1 satellite in the basement. In my master bedroom, I...
Rrodrigm
Apr 21, 2021Initiate
After a couple of days of frustration I realized the problem in my case was the Mac access control. I login in the url 102.68.1.1 as admin, Under advanced -> access control I turned it off that solved my issue. Immediatelly devices connected to the closes satellite and router. I hope that helps.
Good luck!
- HanluuMay 24, 2021GuideWork very well after turn off access control. Thank you very much.
