Retired_Member
Dec 19, 2017Device Requires Iphone Setup on 2.4G Network
I beleive this issue has been discussed before in another post asking about 2 SSIDs for the 2.4 and 5G networks. Part of the 'fix' was to reconfig(?) the Orbi to show the 2 SSIDs. My curr...
Retired_Member
Dec 19, 2017
Something else I thought of last night was to enable the guest 2.4g network. Then log my iphone into the guest network. I tried it for a few minutes but it didn't work. The weather station still would not connect. It may be because the app for the weather station is a bit quirky.
Technically this should work right? Iphone is now on a 2.4G network?
Thanks
st_shaw
Dec 19, 2017Master
Turn off your satellite(s).
Go into Orbi's admin GUI and set 5 GHZ power on the lowest setting (25%).
Now move far, far, away from Orbi (with a few walls between, maybe outside, maybe on the other side of the house) until you can no longer get a 5 GHz connection.
Your iPhone will be forced to connect on the 2.4 GHz band.
Setup what you need to setup.
Put Orbi settings back to where they were.
- Retired_MemberDec 19, 2017
Thanks...not exactly. What did work was to reduce power on the 5g and turn off one of the sats (closet to the weather display). The phone went to 2.4 but the weather display still would not connect. Moved the weather display right next to the Orbi router (up stairs) and the weather display connected. The phone was back on 5g. That's why I think there's something wrong with the weather display. Got a note back to LaCrosse. Thanks again.
