p_haze
Nov 12, 2018Tutor
Device requiring 2.4 ghz band and set up through smartphone
I am trying to set up a device that only works with the 2.4 ghz band and has to be set up using an app on my S9. For this device, it asks me to select the wifi network (from a list of all visible net...
Nov 12, 2018Guru - Experienced User
Try turning down the 5ghz radio power from 100% to 25%. Found under Advanced Tab/Advanced Settings/Wireless Settings.
Try setting WPA2 and AES only. If this fails, try WPA and TPIK or Auto.
Try setting manual channel 1 as well on 2.4Ghz.
p_haze
Nov 12, 2018Tutor
Thanks, is this in the Orbi app?
