p_haze
Nov 12, 2018Tutor
Device requiring 2.4 ghz band and set up through smartphone
I am trying to set up a device that only works with the 2.4 ghz band and has to be set up using an app on my S9. For this device, it asks me to select the wifi network (from a list of all visible net...
p_haze
Nov 13, 2018Tutor
I tried reducing the power of the 5 ghz band. That did not seem to help but will try the other suggestioins as well.
The device is called "Rotimatic". It is a food robot for baking flatbreads.
SeaMonkey80
Nov 13, 2018Apprentice
https://rotimatic.com/testimonial/unable-to-connect-to-wifi/#
Looks like it is a problem with the device. Contact their tech support and see if they can help. Btw, my cousin has the rotimatic. It is awesome! I don't think he ever connected to the wifi though.
- p_hazeNov 13, 2018Tutor
I tried their support first. They asked me to connect the device using mobile hotspot which worked. So they said that the device is fine and that I should contact router manufacturer/ISP.
Connecting to the mobile hotspot allowed for the download of latest firmware/algorithms. But for continued support/updates it needs to be connected to wifi. Otherwise, I am able to use the normal functionalities.
