p_haze
Nov 12, 2018Tutor
Device requiring 2.4 ghz band and set up through smartphone
I am trying to set up a device that only works with the 2.4 ghz band and has to be set up using an app on my S9. For this device, it asks me to select the wifi network (from a list of all visible net...
rams08
Jan 19, 2019Tutor
I'm having the same connection issue. Already reduced the 5ghz wifi to 25% power. No Luck. Anyone has any solution.
