_JW's avatar
_JW
Follower
Feb 06, 2020
Device Text Speed Much Lower than Orbi App Speed
I have just purchased a set of 2-unit RBK50 for a 1400sq.ft apartment. App shows download and upload speeds at 450+Mbps but speed test apps on devices show only 80-100Mbps download and 10-12Mbps upload. Can this be resolved?
  • FURRYe38's avatar
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
  • plemans's avatar
    one thing to keep in mind, if you're running the speedtestt in the orbi app, it actually hosts the test off the router. so its a hardwired speedtest from router to isp. If you then test with the offical speedtest app, it hosts on your phone and that'd be the wireless speed from ISP------router----device. usually the wireless and device are the bottleneck.
    For that testing, FURRYe38 had good recommendations for checking wireless.
    • FURRYe38's avatar
      WiFi Sweet Spots is a good start for mobile devices.
