BrianG123
Mar 02, 2019Aspirant
Devices are connected to Orbi router but aren't able to access the internet
I've had my Orbi system with its Satalites for a few months now and have done all the changes so the Verizon gateway doesn't work along side of the Orbi System, but this week I have begun to have pro...
BrianG123
Fios G1100
and most likely Router mode, ive never seen anywhere offer AP mode
ekhalil
Mar 02, 2019Master
BrianG123 wrote:
Fios G1100
The issues you're having are likely caused by double NAT in your network. The FIOS G1100 is a router and when you add Orbi as a router you can have many issues caused by having multiple routers in the network. You have two options:
- Keep the G1100 as the main router and change Orbi to AP Mode
- Keep Orbi as the main router and change the G1100 to Bridged Mode.
