hoverduck
Aug 24, 2019Aspirant
Devices attached to satellites unable to talk to each other
For the last few weeks I've noticed issues where devices on my network aren't able to reliably talk to each other. Specifically I have a NAS and a server PC attached via Ethernet to a satellite in t...
Aug 24, 2019Guru - Experienced User
Is the RBS wired or wireless connected to the RBR?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Port Fowarding isn't used needed for internal LAN side connections...
hoverduck
Thanks for the quick response and all the suggestions. I'll give them a try and report back, but in the meantime here are the answers to your questions:
Wireless
~5000 sq ft
I don't have exact measurements, but a rough guess is about 30ft.
I initially saw the problem with 2.4GHz set to Auto, but I've since reconfigured to channel 4. I'll try 1, 6, or 11 next.
No, not really. I see a very faint signal from one neighbor, but not enough to really connect to.
Yeah, I know. I just mentioned that as a point to prove that there's at least one network pathway from laptop -> RBR -> RBS -> server. Going via the server's local IP doesn't work, but going via the external IP with port forwarding the Orbi routes the data just fine.
No, is this recommended anywhere?
- FURRYe38Aug 24, 2019Guru - Experienced User
Why not put the Server connected at the RBR iinstead of the RBS?
Factory resets have proven to help fix odd issues seen after FW updates.
- hoverduckAug 25, 2019Aspirant
I can't relocate the server itself, so I'd need to run Ethernet across the house...possible, but part of the reason I bought this system was in hopes of avoiding that. And besides...if I connected the server to the RBR then I'd just reverse the problem and have issues when my laptop is connected to the RBS instead (which is less frequent, but still a fundamental problem).
Interesting. I guess I'll give that a try.
- FURRYe38Aug 25, 2019Guru - Experienced User
Let us know how it goes...
