bashfulrobot
Nov 27, 2018Tutor
Devices blocked constantly
Hi there, for some reason my orbi keeps locking devices. When I log into the interface, they show us blocked and then I have to manually toggle them. After of time, the devices end up being blocked ag...
Nov 27, 2018Guru - Experienced User
What FW version are you using? Theres been others reporting problems with Access Control. Might be best to disable it until next FW update.
bashfulrobot
Nov 28, 2018Tutor
I'm not in front of my device but it is the most recent version. I checked for updates yesterday.
