bashfulrobot
Nov 27, 2018Tutor
Devices blocked constantly
Hi there, for some reason my orbi keeps locking devices. When I log into the interface, they show us blocked and then I have to manually toggle them. After of time, the devices end up being blocked ag...
bashfulrobot
Nov 28, 2018Tutor
I'm not in front of my device but it is the most recent version. I checked for updates yesterday.
Nov 28, 2018Guru - Experienced User
You might try a factory reset on the router and set it up from scratch, go in and do some IP address reservations for the devices you want to put in the access control, then setup access control.
