jwhite518
May 05, 2020Tutor
Devices blocked from each other on LAN
I'm trying to connect from one laptop on my network to another using an app that runs on port tcp/27401. I know the app is running and the port is up and listening. (validated with netstat.) But I ca...
- May 05, 2020
jwhite518 wrote:I'm trying to connect from one laptop on my network to another using an app that runs on port tcp/27401. I know the app is running and the port is up and listening. (validated with netstat.) But I can't connect. By way of troubleshooting I tried a simple ping from A to B, and that isn't working either. Is there some setting on the ORBI that prohibits LAN devices from seeing each other?
(One is on the 2.4Ghz WiFi and the other is on the 5Ghz WiFi, if that makes any difference.
The Guest WiFi has a provision to prohibit devices from contacting each other. My assumption is these devices are not on the Guest network.
2.4G vs. 5G has no relevance.
Windows computers default to "not respond to ICMP (ping)", which could explain not being able to ping in one (or both) directions.
Do you have a network scanner program that can test for open ports?
CrimpOn
May 05, 2020Guru - Experienced User
- jwhite518May 05, 2020Tutor
Ta Daa! That was the answer. Windows Firewall. I added a rule to allow my app port, and now all is well. Thanks!
I didn't realize that Windoze blocks ICMP by default.
