salma733
Aug 16, 2019Aspirant
Devices cannot connect to 5GHz channel on orbi rbk50
Hi Community, I have problem with my home network on netgear orbi rbk50. so i have samsung galaxy s10, galaxy note 9, google pixel 3 which i believe they were all 5Ghz capable, as they were pretty ...
CrimpOn
Aug 16, 2019Guru - Experienced User
Yes, these devices should be capable of connecting to the Orbi at 5G. Please describe some things.
- How far apart are the RBR50 (router) and RBS50 (satellite)?
- Where are these Android devices placed in relation to the Orbi's?
Thanks
salma733
the answer for the questions is:
1. the distance between rbk50 router and its satellite around 26ft (8m) and between them is one concrete wall, fyi, it says on my web settings for netgear orby, the satellite connection status is "good"
2. my family uses those devices inside the house also the router and the satellite, never further than 10 meter away from the router or the satellites. my house indeed built with concrete walls, not wood nor particle board, but we have spacy and wide room with no obstacle between the mesh system and the devices, thankyou
- CrimpOnAug 16, 2019Guru - Experienced User
What happens if one of the devices is turned off, put in the same room as either the router or satellite, and turned back on?
Does it connect at 5G in this condition?
(concrete has a much greater impact on 5G signals than on 2.4G signals)
- salma733Aug 16, 2019Aspirant
did as suggested, but with no luck.
additionally, i also have 3 PC, all with 5ghz wireless card capable, and all of the three were able to connect automatically to orbi 5ghz channel, with the two of it separated with a concrete wall to the router, but keep maintaining a solid 5ghz connection... funny
- ekhalilAug 17, 2019Master
I would try the following:
- Change the current 5 GHz channel to another channel and see if you will see improvements.
- Reduce the power of the 2.4 GHz link, and see if things get any better.
