CurseLikeaSysAd
Jan 24, 2021Aspirant
Devices connect to Orbi network, some devices don't get internet though (Orbi RBR850)
I've spent countless hours searching this forum, rebooting my ISP modem, rebooting and re-configuring my RBR850 (with 2 satellites) multiple times today. The network is set up. I have 20 devices ...
Jan 24, 2021Guru - Experienced User
What are the devices that are failing to connect to the internet?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
