CurseLikeaSysAd
Jan 24, 2021Aspirant
Devices connect to Orbi network, some devices don't get internet though (Orbi RBR850)
I've spent countless hours searching this forum, rebooting my ISP modem, rebooting and re-configuring my RBR850 (with 2 satellites) multiple times today. The network is set up. I have 20 devices ...
Jan 24, 2021Guru - Experienced User
What are the devices that are failing to connect to the internet?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
CurseLikeaSysAd
Jan 25, 2021Aspirant
FURRYe38 wrote:What are the devices that are failing to connect to the internet?
-Hi Furry - they are an iPad (previous gen, not the latest Pro crop) and a Macbook (latest gen, not Pro, not M1)
-I updated my Orbi system to the latest Firmware yesterday as a starting point when I did a clean install/config of the orbi system
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?It's a Fios - just received the hardware a few months ago - will check on the ONT and NG mfr and model #, but would this be the issue if over a dozen other Apple (iPad, MacBook, iPhone) and Amazon and Ring and Sonos products connect seamlessly?)
- The router is definitely more than 30 feet from either satellite, but they have connected to the router and show strong signal. I'd be really surprised if that was the recommended range - I didn't see it on the link above, but thank you for sharing that.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).-Thank you for the suggestion - I'll have to give this a try when remote school/work/etc are over since I can't disable the wifi during the day.
- Thank you again for this - will give it a try. Truly Appreciated.
