eddy08
Feb 27, 2020Aspirant
Devices connected via WIFI are not able to find divices connected via LAN on Orbi RBR50
I have an issue with my connection. Devices connected via WIFI are not able to find divices connected via LAN on Orbi RBR50. Im trying to connect to my TV which is connected Via LAN with my Ipad that...
CrimpOn
Feb 27, 2020Guru - Experienced User
eddy08 wrote:I have an issue with my connection. Devices connected via WIFI are not able to find divices connected via LAN on Orbi RBR50. Im trying to connect to my TV which is connected Via LAN with my Ipad that is connected Via WIFi to the same router.
Just to clarify, the TV and the iPad are both connected to the Orbi. There is no other "LAN" equipment in the mix?
Are there other LAN connected devices that the iPad can connect to (perhaps a printer, desktop, or laptop)?
What is the IP address assigned to the TV? To the iPad?
- eddy08Feb 29, 2020Aspirant
Hi CrimpOn,
The TV is connected via LAN to the Router and the Ipad is connected via WIFI. There are no other LAN connected devices that the iPad can connect to.
The Router is set to DHCP
The TV is assigned IP address 192.168.1.13 on LAN and the Ipad is assigned 192.168.1.23 on WIFI
- CrimpOnFeb 29, 2020Guru - Experienced User
eddy08 wrote:There are no other LAN connected devices that the iPad can connect to.
I am a little slow sometimes:
- There are no other devices connected to the Orbi LAN, or
- There are other devices, and the iPad also cannot connect to them
I do not have a Samsung TV, so it is not clear to me what the purpose is of connecting an iPad to the TV. Is there a special "app"?
