eddy08
Feb 27, 2020Aspirant
Devices connected via WIFI are not able to find divices connected via LAN on Orbi RBR50
I have an issue with my connection. Devices connected via WIFI are not able to find divices connected via LAN on Orbi RBR50. Im trying to connect to my TV which is connected Via LAN with my Ipad that...
Feb 27, 2020Guru - Experienced User
Be sure the TV is set to be sharing any kind of app information to the ipad first off. Check with the TVs mfr for help and information on if there is any kind of configurations needed on the TV so that devices can see the TV. Orbi doesnt' block any LAN side connections by default.
Do you have any Armor or Circle features enabled on the RBR?
eddy08
Feb 29, 2020Aspirant
Hi FURRYe38,
I have no Armor or Circle features enabled on the RBR. The TV is a Samsung TV and the Router is set to DHCP. There is no fix IP address on the TV.
- FURRYe38Feb 29, 2020Guru - Experienced User
I would make sure that the TV has any kind of sharing features enabled if needed. Contact the TVs mfr support site for help and information regarding on how to get the TV and mobile apps connected. There should be nothing on Orbi that would be blocking anything since the LAN and WLAN are all on the same side of the network.
eddy08 wrote:Hi FURRYe38,
