michabbb
Apr 19, 2018Aspirant
Devices connected via WIFI are not able to find DLNA services outside the WIFI network
hi there, my situation: ----> INTERNET ---> FRITZBOX ----> RBR40 (router mode) ----> WIFI DEVICES (my phone) | DLNA ...
- Apr 19, 2018
Connect your DLNA devices to the Orbi router, not the fritzbox.
If the fritzbox has a router built in, you could change the Orby system from router mode to AP mode, LAN to LAN.
Or use the DMZ on the fritzbox for the IP address the Orbi router gets from the modem and use the Orbi router in it's current router mode configuration.
Apr 19, 2018Guru - Experienced User
