Tcg777
Feb 11, 2019Follower
Devices connecting to farthest location
I have devices that are connecting to the router but are closer to the satellite and vice versa. They are actually connecting to the weaker of the signals. Is there away to intentionally connect de...
Feb 11, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Tcg777 wrote:
I have devices that are connecting to the router but are closer to the satellite and vice versa. They are actually connecting to the weaker of the signals. Is there away to intentionally connect devices to the closer satellite of router?
