vtrusty
May 25, 2017Star
Devices don't switch between router and satellite
does anyone else fail to have their devices swap between router and satellite? i swear this used to occur seamlessly out of the box, but after a couple updates i can literally start right next to...
mccx
May 26, 2017Star
I'm having the same issue. Bought the devices new a couple weeks ago, starting with v1.9, then updated to v1.10, same result. I also tried the v1.11 beta firmware but the main router is rebooting every 10-15 mins, so I had to revert back to v1.10 to make it stable, but the not switch issue still exists. As a matter of fact, some devices won't even connect to the satellite even if it's right next to it, they will just connect to the router no matter what.
This is some what frustrating.
mccx
May 26, 2017Star
Also, how do we tell if the device is connect via 2.4Ghz or 5Ghz? From some older screenshots, I see they show under attached devices, but with the latest firmware, it just show wireless.
- DukeSilverMay 26, 2017Star
- Go to the debug page and enable telnet
- Telnet into the router
- Execute the following:nvram set enable_adv_attached=1
nvram commit
- Exit telnet- Go to debug page and disable telnet
- mccxMay 26, 2017Star
Thank you! It worked.
I also want to provide some feedback. I have been playing around with different version of the firmware and now I'm running:
Router: v1.10.2
Satellite: v1.11.2 beta
And I have been having very good results. The router no longer restarts every 10-15 mins. The satellite is also working fine, picking up close devices and devices are able to switch between router and satellite. Also, most of my devices are now connecting via 5Ghz.
- vtrustyMay 26, 2017Star
what does that command do, basically bring back additional device info that was stripped in the newer firmwares?
- st_shawMay 27, 2017Master
DukeSilver wrote:- Go to the debug page and enable telnet
nvram commit
This no longer works on newer firmware. For me anyway. I'm on V1.10.1.2.
- vtrustyJun 02, 2017Star
i guess we just chalk this up as a feature that's currently not working? do we have any Netgear admins that monitor the forum? I would love to have one of them chime in for some insight.
