vtrusty
May 25, 2017Star
Devices don't switch between router and satellite
does anyone else fail to have their devices swap between router and satellite? i swear this used to occur seamlessly out of the box, but after a couple updates i can literally start right next to...
mccx
May 26, 2017Star
Also, how do we tell if the device is connect via 2.4Ghz or 5Ghz? From some older screenshots, I see they show under attached devices, but with the latest firmware, it just show wireless.
DukeSilver
May 26, 2017Star
- Go to the debug page and enable telnet
- Telnet into the router
- Execute the following:
nvram set enable_adv_attached=1
nvram commit
- Exit telnet
- Go to debug page and disable telnet
- mccxMay 26, 2017Star
Thank you! It worked.
I also want to provide some feedback. I have been playing around with different version of the firmware and now I'm running:
Router: v1.10.2
Satellite: v1.11.2 beta
And I have been having very good results. The router no longer restarts every 10-15 mins. The satellite is also working fine, picking up close devices and devices are able to switch between router and satellite. Also, most of my devices are now connecting via 5Ghz.
- vtrustyMay 26, 2017Star
what does that command do, basically bring back additional device info that was stripped in the newer firmwares?
- st_shawMay 27, 2017Master
DukeSilver wrote:- Go to the debug page and enable telnet
- Execute the following:nvram set enable_adv_attached=1
nvram commit
- Exit telnet- Go to debug page and disable telnet
This no longer works on newer firmware. For me anyway. I'm on V1.10.1.2.
- vtrustyJun 02, 2017Star
i guess we just chalk this up as a feature that's currently not working? do we have any Netgear admins that monitor the forum? I would love to have one of them chime in for some insight.
- DukeSilverJun 02, 2017Star
I executed those steps a few months ago. The configuration changes have persisted across firmware updates. I am on latest firmware and still see the radio connection for each client.
- st_shawJun 02, 2017Master
DukeSilver wrote:I executed those steps a few months ago. The configuration changes have persisted across firmware updates. I am on latest firmware and still see the radio connection for each client.
Just to clarify my comment a bit... This configuration change used to show whether a device was connected to the router or satellite. This no longer works.
The change does, however, show whether the client connection is 2.4 G or 5 G.
