XBond
Oct 09, 2016Apprentice
Devices get stuck connected to Orbi in 2.4 GHz mode
 Wondering if people are running into the same issue.     Background: 2 story house. Orbi router in downstairs office. Satelitte upstairs.     After a bit of testing, I was able to find a location for...
peteytesting
Oct 09, 2016Hero
hi
sounds like a band steering issue , the next firmware release will help resolve this , might see next fw in early november
pete
Skrymir
Oct 10, 2016Guide
pete,
Do you have a link to the details on the upcoming firmware release?
Thanks,
Josh
- XBondOct 10, 2016Apprentice
A nice feature would be if I could turn off a band. E.g. just broadcast the 5Ghz band. That would solve this issue in that devices could only connect to e.g. the 5GHz band. And if I didn't get a connection, then:
1. It is my own fault since I turned off the band. And chances are great that I know why I am not getting a connection, since, well, I turned off the band. :)
2. It lets me troubleshoot, say, the location of the router and satellite.
Some could argue that it defeats the purpose of the Orbi, but not really. It still does what it is supposed to - give me wider coverage, I just choose with what band.
- peteytestingOct 10, 2016Hero
hi
no word on details for the firmware only its tentive release date
just as a side note you know on most device you can tell it to only connect to the 5 gig band and thus it wont connect to 2.4 gig
pete
Yeah, know how to do it for Windows, but not for the iPhone?
