XBond
Oct 09, 2016Apprentice
Devices get stuck connected to Orbi in 2.4 GHz mode
Wondering if people are running into the same issue. Background: 2 story house. Orbi router in downstairs office. Satelitte upstairs. After a bit of testing, I was able to find a location for...
Skrymir
Oct 10, 2016Guide
pete,
Do you have a link to the details on the upcoming firmware release?
Thanks,
Josh
XBond
Oct 10, 2016Apprentice
A nice feature would be if I could turn off a band. E.g. just broadcast the 5Ghz band. That would solve this issue in that devices could only connect to e.g. the 5GHz band. And if I didn't get a connection, then:
1. It is my own fault since I turned off the band. And chances are great that I know why I am not getting a connection, since, well, I turned off the band. :)
2. It lets me troubleshoot, say, the location of the router and satellite.
Some could argue that it defeats the purpose of the Orbi, but not really. It still does what it is supposed to - give me wider coverage, I just choose with what band.
- peteytestingOct 10, 2016Hero
hi
no word on details for the firmware only its tentive release date
just as a side note you know on most device you can tell it to only connect to the 5 gig band and thus it wont connect to 2.4 gig
pete
- XBondOct 10, 2016Apprentice
Yeah, know how to do it for Windows, but not for the iPhone?
- solty1977Nov 15, 2016Aspirant
Any resolution to the 2.4Ghz band hang ups? I have the same problem where the 2.4Ghz gets stuck and won't switch over. I just updated the firmware to 1.3.0.26 and it still doesn't work very well. I updated my internet to fiber a month ago and my router had to be moved to the middle of the house. The Orbi seemed a great fit to solve the problem of not getting fast service to the other end of the house. I am a little disapointed that you cannot even chose which band you would like to use. My old router (Apple Air Port Extreme) would allow you to pick which band you wanted. I would typically just ignore the 2.4Ghz band. Any other advice or thoughts on ignoring or fixing the hand holding issue of the 2.4Ghz band? Equipment: Iphones, Mac, Ipads, and two Windows 10 laptops. Typical speeds: 100 Mbps Down and 50 Mbps Up when on 5Ghz. Crap shoot with 2.4Ghz.
Thanks!
