XBond
Oct 09, 2016Apprentice
Devices get stuck connected to Orbi in 2.4 GHz mode
Wondering if people are running into the same issue. Background: 2 story house. Orbi router in downstairs office. Satelitte upstairs. After a bit of testing, I was able to find a location for...
JMU1998
Nov 17, 2016Luminary
I have also experienced devices getting stuck on the 2.4ghz band really wish the new Firmware will allow to turn off the 2.4ghz radio off rather than constantly rebooting ever other day.
- peteytestingNov 17, 2016Hero
hmm , if you cross your fingers real tight you might find the tooth fairy brings you that for xmas :)
- IrishbrowncoatDec 14, 2016Star
I have noticed over the past few days that my Orbi Satelitte is connecting to the main Router with a 100 MBPS connection. Now I may be off here but I was under the understanding that the network backmesh was 5GB (I assumed an AC back end mesh...is that even possible if it connects with only 100 MBPS).
If that is the case with your situation it may explain the drop in speed when on the Satelitte as I dont think it can push top end speeds if the units back end is being provided over a 100 MBPS connection?
Again I could be way off :)!!!
- rhester72Dec 14, 2016Virtuoso
How do you know the connection is only 100Mbps? (Yes, it's *very* unlikely that's the case, as you noted.)
Rodney
