ChiefNomad
Jul 09, 2018Aspirant
Devices jumping from router to satellite
Hi,
On the RBR50 Orbi system, is there a way to isolate a MacBook for example so that it only connects to the router and never jumps to one of the satellites? Or for example, keep one of the de...
Jul 09, 2018Guru - Experienced User
Are Daisy Chain, MIMO and Fast Roaming enabled? Try disabling these on the router, reboot and see how it goes...
- ChiefNomadJul 17, 2018Aspirant
I'll give those a shot and see what happens as a result. Will post back with an update once I try your suggestion. Thank you.
- FURRYe38Jul 17, 2018Guru - Experienced User
:smileywink:
