vinrich
Nov 20, 2018Aspirant
Devices keep connecting to 2.4GHz on my Orbi RBK50
I'm having an issue with my Orbi. Whenever my devices are connected to the main Orbi router, it's always on 2.4GHz. However, when they are connected to the Orbi Satellite, it's 5GHz. I've tried reset...
ekhalil
Nov 20, 2018Master
vinrich wrote:
I'm having an issue with my Orbi. Whenever my devices are connected to the main Orbi router, it's always on 2.4GHz. However, when they are connected to the Orbi Satellite, it's 5GHz. I've tried resetting my Orbi router. And it's still the same
It's the device that chooses which radio band to connect to based on the relative strength of the signals coming from both bands and the noise on the respective bands.
It can be that there are other SSDID's from your neighbours using the same as your 5GHz channel and is stronger around where your Router is and weaker around your Satellite.
Please make a scan and try to select the most appropriate channels for both bands. This is vital for the performance of your wifi network.
